MAS Can i Take it off
Old Mar 6, 2003 | 07:58 PM
RedZ-28's Avatar
What would happen if you took your MAS off. Would it trow a SES light or what.
Old Mar 6, 2003 | 08:46 PM
turbo_Z's Avatar
MAS?
maybe you are talking about the Mass Air Flow(MAF) the large sensor connected to the intake end of your intake elbow. if so then you will need to keep that connected since it relays vital information, specifically the volume of air entering your motor, for the PCM.
Old Mar 6, 2003 | 09:21 PM
turbo_Z's Avatar
Originally posted by ACA Performance
The PCM should just go into speed density mode.
true...
but unplugging the MAF will throw SES and speed density is inferior to a MAF sensor so theres really no point to unplugging it anyway.
Old Mar 6, 2003 | 10:25 PM
cop01's Avatar
its a good way to test your mafs, if your car runs better without the sensor plugged in, you need a new sensor
Old Mar 8, 2003 | 02:28 PM
RedZ-28's Avatar
I dident think it plyed that big of a role. So is it worth gettin aftermarket.
Old Mar 8, 2003 | 03:24 PM
Buttercup's Avatar
It is one of THE most important sensors. The right way to remove it completely is reprogram the PCM to run specifically in speed density mode. This requires lots of tuning to get it right when you start adding mods.
I would leave the MAF alone and concentrate on *real* mods... even if that means getting some dirt under the fingernails
Old Mar 8, 2003 | 04:02 PM
Larnach's Avatar
Not true. Maybe without programming, but speed density is much better when used with the right programming.
Old Mar 8, 2003 | 04:15 PM
turbo_Z's Avatar
that must be why speed density has been phased out of every car built since the mid 90's.
Old Mar 8, 2003 | 04:24 PM
Larnach's Avatar
... lets see... how many top end racing ECU's use MAF?... lets see..... 0. Not one. Motec, F.A.S.T, Electromotive, Magnetti Marelli, all use speed density.
Why? Do you know the difference between the two?
Old Mar 8, 2003 | 04:28 PM
Larnach's Avatar
I hereby cancel the above post
I was mistaken.
Old Mar 8, 2003 | 04:44 PM
Buttercup's Avatar
Because MAF sensors adapt well to small differences, such as manufacturing variances on productions vehicles, making it more attractive to the EPA maybe????
When either is tuned correctly I really don't see any advantages on either side, with the exception of cost reduction and the ever so slight flow loss reduction of an SD system.
blueta
Feb 2, 2004 07:52 PM
DavidNC
Aug 22, 2003 01:59 PM
lordmetalz28
3rd Gen / L98 Engine Tech
Jun 18, 2003 07:32 PM
