Marking harminc balancer hub
Re: Marking harminc balancer hub
Originally Posted by ZMAN Z28
I'm in the process of pulling my opti. How do I mark the harmonic balancer hub to the crank? Or do I even need to mark it before I pull it off?
Z
Z
The damper will likely be severely rusted to the hub. Use a lot of good penetrating oil to start. If that fails, look at Shoebox's Tech Pages for the correct way to pull the damper with a 3-jaw puller.
