Mark in the crank?
Old Jul 17, 2004 | 12:55 PM
jdizzell's Avatar
Mark in the crank?
As I was pulling the crank hub off, the crank move just a little from TDC.
I see a slit on the crank, does that indicate anything? If not, I'm going to be in that much trouble when adjusting the valves if I'm off TDC a little?
Also if you ask yourself why I dont use the crank hub arrow when I reinstall it, is because it was off when I sent the #1 piston to TDC on the compression stroke.
Old Jul 17, 2004 | 03:19 PM
Do you mean the keyway for the key the factory hub does not use?
Visual
Old Jul 17, 2004 | 06:15 PM
jdizzell's Avatar
No, not that part. The part that the hub comes off of.
Old Jul 17, 2004 | 06:33 PM
Mtrhds94Z's Avatar
I think the point of the pic is to show you where the crank keyway should be when #1 or #6 is TDC..
If you 'have the hub off', can't you see the keyway slot?
If it's at 130 o clock it's #1 or #6 is at TDC..
Old Jul 17, 2004 | 06:39 PM
Yeah, I know it was not that part. It was just used for a point of reference.
Old Jul 18, 2004 | 08:16 AM
jdizzell's Avatar
Sorry about that shoebox, I wasn't thinking outside of the box Thanks for the reference!
NewsBot
Apr 7, 2015 10:50 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
ChrisFrez
Dec 7, 2014 11:32 AM
Z284ever
57
Aug 4, 2002 03:48 PM
