March Underdrive Vs. Charging
Old 05-01-2007, 07:47 AM
THE_RUCKUS's Avatar
Has anybody experienced any significant voltage drops when running the March 2 pc (crank / alt) underdrive set on the LT1? i.e. 12.6v stock compared to after underdrive install.
A part number for the belt would also be much appreciated.
regarding part MCH-4485
THE_RUCKUS is offline
Old 05-01-2007, 09:45 AM
mzgp5x's Avatar
Running the LT1 underdrive pulley. Napa has all of the 6 rib "A" section belts. I have alot of mods. The stock alt has been holding 13.4 volts @ approx 1500 rpm.
Running...
electric WP.
electric vac pump.
Acceleronics inj driver for 72# Siemens 4/1 amp.
elctric H2o/ meth injection
2 walbro 255 lph pumps.
KB BAP electric driver on pump #1.
2 hi-flo fans.
Wideban O2 dynojet.
(97ss - 383 - D1) Hope this helps.
mzgp5x is offline
RUENUF
03-13-2016 03:37 PM
68camaroboltz
10-05-2015 01:46 PM
sleeperZ96BT
09-09-2015 08:28 AM
WPHIG2
08-27-2015 06:37 AM
Slayer
08-17-2015 03:55 PM
Quick Reply: March Underdrive Vs. Charging
