March Underdrive Vs. Charging
Has anybody experienced any significant voltage drops when running the March 2 pc (crank / alt) underdrive set on the LT1? i.e. 12.6v stock compared to after underdrive install.
A part number for the belt would also be much appreciated. regarding part MCH-4485 |
Running the LT1 underdrive pulley. Napa has all of the 6 rib "A" section belts. I have alot of mods. The stock alt has been holding 13.4 volts @ approx 1500 rpm.
Running... electric WP. electric vac pump. Acceleronics inj driver for 72# Siemens 4/1 amp. elctric H2o/ meth injection 2 walbro 255 lph pumps. KB BAP electric driver on pump #1. 2 hi-flo fans. Wideban O2 dynojet. (97ss - 383 - D1) Hope this helps. |
