map,vaccum, and running problems
Old Aug 30, 2007 | 01:25 PM
  #16
LT4 Formula's Avatar
If you have an intake gasket leaking it will be running lean when tuned for your 44lb injectors in open loop. Probably cause your high map as well.
Old Aug 30, 2007 | 01:51 PM
  #17
Intake manifold bolts tight?
Old Aug 30, 2007 | 09:40 PM
  #18
mrmint69's Avatar
What brand of injectors? Did you use a lot of sealant on the rear and front of the manifold. I saw where one guy used to little and had to redo it and he still didn't use enough. It took him four tries to get it right. You might be able to feel back there and see if you have any oil coming out. The front is mostly by sight.
Old Sep 1, 2007 | 11:09 PM
  #19
CamaroZ2869C's Avatar
the back was leaking oil. but when i removed the intake i found another comp r lifter it pieces. im getting comp oem at summit tomorrow. also the injectors are accel 44 lb.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Amshnock
14
Jan 18, 2015 11:47 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
