Map sensor wire
Old Mar 6, 2020 | 06:38 PM
94Z28LS1toLT1's Avatar
Map sensor wire
Hey guys when I was driving my camaro to work in the morning it was great,when I went to get my daughter's school still great,after I got her and we headed home my engine light came on @ wot,didn't show any signs of no problem etc.
When I pulled the car in the garage I look around the engine and the wires to make sure the sensors were connected good. And the map sensor one the connector is broken I pushed it more up with my fingers,I could tell if it was all the way in or not. And the engine light turned off n the fans too. (I know the fans come in certain ses light scenarios).
I took the car again, I did a wot and no engine light came on. So I just wanted to know if the map sensor was the issue hopefully. I ordered a new map sensor connector from rockauto,just so I can have a great connection with the map sensor.
Old Mar 7, 2020 | 12:00 PM
Chimera96's Avatar
Re: Map sensor wire
if you are talking about the green connector that plug into MAP the clip can break so the plug can get lose or come out. You can buy just the plug body and use a tool to get the pins out of the old one. What I did
..or splice in a new pigtail one if that's what you got on RA
Old Mar 7, 2020 | 05:47 PM
Re: Map sensor wire
hey chimera yea that green connector. And I'll just splice a new one from RA it's gonna arrive by Tues. Thank you on the response.
Old Mar 7, 2020 | 07:56 PM
JakeRobb's Avatar
Super Moderator
Re: Map sensor wire
Maybe you’ll get lucky with that bad connector, but the first thing to do when the engine light comes on is always to scan it for codes.
camarors96
V6 Tech
Feb 23, 2011 07:28 PM
1crazylt1
Aug 17, 2005 07:38 PM
RansZ28
Dec 2, 2004 10:31 PM
RobbyRob
Nov 14, 2004 02:09 PM
BigTedz28
Sep 30, 2004 07:18 PM
