Map Sensor Question
Map Sensor Question
I understand that the green connector from the engine harness is to be connected to the MAP. What is the red connector suppose to go? Right now, I have it loose
and Im not sure where its suppose to go!
They look identical.
and Im not sure where its suppose to go!They look identical.
Re: Map Sensor Question
Look at Shoebox's wiring harness photo for a 1995. That may help. Appears the connector for the EVAP purge solenoid is red, and that would be near the MAP sensor.
http://shbox.com/1/harness.htm
kinda of a silly question, i dont have my factory manual infront of me, but isnt the 3.4L motor have a different harness and map sensor. I mean it should be the same function but I dont know if it varied between motors, or even years.
1995 Really Stock (RS) Camaro---now featuring LT1 powah!
thanks guys.
i had someone do an engine swap for me, but i often find missing plugs here and there. the car is running, but im not sure of a couple of things
im not even sure i have that canister on the car. im going to give it a look see this afternoon
