Which MAP Sensor for '93 24x LT1?
Old May 8, 2013 | 11:24 PM
JamesZ28's Avatar
Ok so I recently installed the 24x conversion on my '93 LT1 along with some other mods. A question I ran into early on was what MAP sensor would I be using. When my harness was being built they asked what I'd want and I believe I told them a 3 bar (Does this make a difference in what plug they'd put on the harness or something?). Anyway I gave them a call and they told me I'd be able to use my current sensor since "they're all the same." Anyway that's where my main question comes in for everyone here. We tried hooking up the plug in my new harness to my '93 map sensor and the plug is slightly different. Very close to being the same, but not quite. Does anyone here know what sensor I need? LS1? I noticed the part number on all '93-'97 LT1 sensors is the same so I'm just kind of lost here. Any help would be greatly appreciated! Thank you!
Old May 9, 2013 | 05:03 AM
Re: Which MAP Sensor for '93 24x LT1?
Are you running forced induction in excess of 15psi boost? That's the only application that would use a 3 bar map sensor. Your stock 93 sensor is 1 bar.
Old May 9, 2013 | 10:49 AM
JamesZ28's Avatar
Not to start with. For now it'll be around 8psi then after upgrading the fuel system and switching to e85 I'm shooting for 16-20psi. I've figured out that I'll need a different map sensor and found that the 89 turbo t/a had a compatible 3 bar map. I can buy a sensor for one of those from oreillys in town, but I'm not sure which one to get or if there is really even a difference. Can anyone here offer up their opinion on these? Which would work for me?
this one is the AC Delco (new)** 213-1562
Delphi Automotive PS10081 - Map Sensor | O'Reilly Auto Parts
this one is the AC Delco (old)* 213-101
BWD EC1678 - Map Sensor | O'Reilly Auto Parts
Old May 9, 2013 | 04:54 PM
The photos I have seen of various MAP connectors show that the "keying" is different for 1 bar and 3 bar.
For the two parts you listed, the first one seems to be for use in normally aspirated 89 applications (1 bar), while the second one is for the 89 turbo application (3 bar?).
Are you asking should you initially tune it using a 1 bar sensor? That would seem to make sense if it not going to be boosted for a while. But then there's the issue of having to change the connector.
Or maybe I just missed the point of the question.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Queens94z28
Dec 20, 2014 09:11 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
