map sensor?
Old Apr 19, 2010 | 03:09 PM
tonyv's Avatar
map sensor?
Hi i have a 1995 camaro lt1 with heads intake and gm 847 cam, and was tuned by madz z28, the problem i am having is when i start my car and put it in reverse it idles down to like 500rpm and service engine comes on with code 33 map voltage high, but once its warmed up it works great, the question is is the sensor shot,or is this normal with a big Cam thanks Anthony
Old Apr 19, 2010 | 05:12 PM
When the idle goes that low, the MAP is likely throwing the code, because of lower than expected vacuum. I would say the code is a result of engine operation-not the cause of a problem.
Old Apr 19, 2010 | 05:16 PM
The code sets when MAP exceeds something like 68kPA at closed throttle. As Rob/Shoebox points out, that's probably an actual operating condition. Likely due to the cam, and the tune. It may be made worse by an IAC sensor that isn't reacting to the reduced RPM in reverse. The IAC should be able to put the idle back where it belongs. If it can't, the IAC isn't working correctly. Put a scanner on it and observe the MAP and the IAC counts.
Old Apr 19, 2010 | 07:10 PM
tonyv's Avatar
hrmm i was wondering if anyone can tell me what is the difference with or without oil cooling if i were to buy a new iac thanks Anthony
Old Apr 19, 2010 | 07:11 PM
Never have figured that one out.
Old Apr 19, 2010 | 07:13 PM
tonyv's Avatar
lol so does it matter
Old Apr 19, 2010 | 07:59 PM
Peytons'z's Avatar
IAC = Idle air control. http://shbox.com/1/iac3.jpg
Nothing to do with oil cooling in any way
Old Apr 19, 2010 | 09:34 PM
tonyv's Avatar
Yea I don't understand here's a link to the iac valves I was looking at http://www.rockauto.com/catalog/x,ca...,parttype,6072
Old Apr 19, 2010 | 09:44 PM
...but there are 2 different IACs based on whether it is optioned with an oil cooler or not.
Like I said, I don't know. Just order the one for how your car is equipped.
Old Apr 19, 2010 | 10:36 PM
tonyv's Avatar
yea thanks for clearing that up shoebox, mine is not equipped with the cooler so im good to go, i appreciate the help, Anthony
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
zajones
Jul 30, 2015 02:18 PM
Noct
Jul 14, 2015 01:18 AM
