MAP sensor
Old Jan 4, 2006 | 11:52 PM
iansane's Avatar
MAP sensor
I'm not sure where to post this...
Does anyone have any close up pictures of where the MAP sensor plugs into the manifold of the LT1? Does it use a grommit? Or is there an actual barb fitting and short vacuum tube?
Old Jan 5, 2006 | 07:29 AM
Re: MAP sensor
The MAP sensor has a small nipple/tube that projects down into a hole in the manifold. There is a soft rubber seal that goes over the nipple to seal the sensor to the manifold.
Old Jan 5, 2006 | 07:36 AM
Re: MAP sensor
Old Jan 5, 2006 | 01:49 PM
iansane's Avatar
Re: MAP sensor
Thanks! That grommit, where can you get it? Dealer only?
Old Jan 5, 2006 | 10:56 PM
iansane's Avatar
Re: MAP sensor
Incase anyone does any searching later on I went ahead and called the dealer, part # 1635948 MAP sensor seal $3.48 or something like that. Thanks again shoebox.
Old Jan 5, 2006 | 11:15 PM
Re: MAP sensor
Yep, that's listed on my part numbers page.
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
zajones
Jul 30, 2015 02:18 PM
Noct
Jul 14, 2015 01:18 AM
