manual fan switch
Old Mar 2, 2005 | 10:30 PM
WingZero02's Avatar
manual fan switch
will the fan switch connector fit with my 94 3.4 Camaro v6?
Old Mar 2, 2005 | 10:36 PM
blackztpi's Avatar
Re: manual fan switch
i have no idea. but an easy way to do man. fan switches: cut existing wires and add 2 new ones, run along engine bay and into the PCM grommet in the fireall, up under the dash and into the center colum on the dash. easy and fusable. but don't forget to turn them off when u shut the car off
Old Mar 2, 2005 | 11:42 PM
Red96Lt1's Avatar
Yeah, that's the idea. This should help
Old Mar 3, 2005 | 12:45 AM
WingZero02's Avatar
I'm thinking of getting a manual fan switch that this website sells http://www.lmperformance.com/763/2.html
I have a repair manual for my camaro but it doesnt say where the connector is located in my 3.4L v6 camaro.
Old Mar 3, 2005 | 11:09 AM
Red96Lt1's Avatar
It looks so much better if you make your own. Plus you get the lights. And it also tells you when the PCM turns on the fans.
cristian1311
Nov 23, 2014 02:22 PM
slothgrant
Aug 22, 2002 03:01 PM
x7x7
Aug 15, 2002 06:49 PM
sfGi8nt
Aug 1, 2002 05:54 AM
