manual to auto
Old Jul 12, 2013 | 02:20 PM
1FST4GEN's Avatar
manual to auto
ok the engine that i am rebuilding was originally had a t-56 behind it. well now it will have a 4l60e behind it.
with the balancing of these motors do i need to have the motor balanced with the new flexplate or am i able to just bold a new one on and go? if so what is the flexplate i need as i would like to upgrade from the factory one or is it easier to just use my stock flexplate and swap it over?
Old Jul 12, 2013 | 04:04 PM
Re: manual to auto
Depends whether you are doing an internal or external balance.
Old Jul 12, 2013 | 04:29 PM
1FST4GEN's Avatar
Re: manual to auto
Fred its a stock bottom end. I had it look at and was told to leave it alone cause it was still in great shape. Only thing being done is a cam and heads rebuilt with new springs seals and 1.6rr's
Old Jul 12, 2013 | 04:45 PM
RamAir95TA's Avatar
Re: manual to auto
If you aren't touching the bottom end a stock A4 flexplate will work. LT1s are internally balanced in the front and externally balanced in the rear.
Old Jul 12, 2013 | 04:53 PM
1FST4GEN's Avatar
Re: manual to auto
Ok so just factory replacement
Thanks Joe!
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Rod Bender
Classic Engine Tech
Mar 18, 2015 08:57 AM
jb4xx
Feb 2, 2015 10:00 PM
