Manifold porting advice...
Old Jun 27, 2003 | 06:11 PM
mtxpert's Avatar
I've got a set of ported heads coming and we are port matching my intake but found this:
http://www.azsupersport.com/manifold/MVC-003S.JPG
http://www.azsupersport.com/manifold/MVC-004S.JPG
http://www.azsupersport.com/manifold/MVC-005S.JPG
http://www.azsupersport.com/manifold/MVC-006S.JPG
http://www.azsupersport.com/manifold/MVC-014S.JPG
http://www.azsupersport.com/manifold/MVC-015S.JPG
http://www.azsupersport.com/manifold/MVC-016S.JPG
http://www.azsupersport.com/manifold/MVC-017S.JPG
http://www.azsupersport.com/manifold/MVC-018S.JPG
http://www.azsupersport.com/manifold/MVC-020S.JPG
Should we enlarge the area to fit the gasket?
Mike
Old Jun 27, 2003 | 06:55 PM
SVT Killer LV's Avatar
If you are porting your heads.. go ahead and do it.. why wouldn't you.. I did
Old Jun 27, 2003 | 07:03 PM
AdioSS's Avatar
West South Central Moderator
Definitely wait until you get your heads back and see how the gaskets line up to the ports on them. You don't want to open up the intake, then have the intake ports be a good bit larger than the heads. The air/fuel mixture would have to go up that step which can't be good for flow You'll want as smooth of a transition as you can.
Old Jun 28, 2003 | 08:24 PM
arnie's Avatar
Re: Manifold porting advice...
To answer the ?, yes and no. Enlarge the port, but not to the (same) size of the gasket. I also agree with adioSS. Without visual inspection, you won't know if the head port opening is 'on top' of the gasket size, or a little (1/32" or so) smaller than gasket.
BTW, for those umaware, your discovery should also help with awareness of the mismatch of the pre '96 intake manifold to a set (any year) of aluminum LT1 head intake ports. The oem head ports look like the intake port shape you presented, while the oem ports of the intake/plenum were a true rectangular shape. Whereas your example (while not great, it is not bad) would have the unported intake plenum port smaller on one wall, than the ported head port, with an unported pre '96 oem intake/head assembly, the much worse/undesireable mismatch of larger into smaller exists. That is why you have the oem port shape on the manifold that you have. I trust the intake in the pix is a late '95/'96 or later.
bunker
Aug 31, 2015 01:46 PM
whitehooptie
Aug 17, 2015 08:35 AM
bunker
Aug 1, 2015 09:47 PM
alphaauto
Jul 26, 2015 04:40 PM
13qtr
Jul 19, 2015 05:30 PM
