This should be my last jet hot lt install?
Old Jun 28, 2003 | 09:40 AM
speed76demon's Avatar
Do i have to take the steering knuckle off to get the drivers side header in?? Also if im on a lift i can get them both in from the bottom right?? Also any tips you have i will appreciate thanks for all your help this week is making sure i can get all the bolts off and checking out my car then a week from today its nascar time going to get those headers on as quickly as possible
Old Jun 28, 2003 | 08:48 PM
NEOS97SS's Avatar
just did the install about a month ago and a few hints... after you take off both headers put the pass side in first. i had to disconnect the pass side engine mount and tilt the engine over to put that side in. i put the pass side in from the top too it was easier but watch out for clearence after its in cause the bottom tube on mine rubbed on the k-member or lower a arm youll see when its in its close i had to notch mine out a little. and the drivers side you dont have too take the steering knuckle out but its easier to do it. only 2 bolts and the drivers side should go in in secs literally. have fun and let me know if you have any more questions.
Nov 18, 2023 07:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
GigaMp3z
Feb 20, 2003 02:57 PM
