Mallory 685 mounting locations...
Those of you who have the Mallory 685 ignition box, where do you have it mounted at?
I'm trying to find a good location to mount mine and need some ideas. I don't see anywhere under the hood suitable to locate the thing.
Re: Mallory 685 mounting locations...
The problem with me putting it under the hood is that I do not have a Ram Air car, so my air intake tube runs into the driver's side fender area. That keeps me from mounting the box there, so it will have to go inside the car I guess.
By chance would anyone share a pic of their glove box with it mounted?
i tried the glove box and my overheated????
do your's get warm? as far as i know it's wired up right, used larger gauges of wire to extend the harnesses......not sure what's up, maybe i got a bad box???
Granted, I haven't driven it for real extended periods of time yet or anything, but I have driven it for up to an hour in stop and go traffic with no AC and it mounted in my glove box and it's never given me any problems.
Mine is in the glove box and gets pretty warm there as well. I have never had any problems with it I don't think. I am having one issue but only when I try to run the nitrous. When I use nitrous it will sometimes just freak out and not pull over 3500-4000 until I turn the car off and restart. Its like it is hitting a rev limiter. I suspect either the box or fuel pump. I never had this problem until I installed the box. I have gone over all the wiring countless time to confirm its not the box. All features work when not spraying. Anyone have any suggestion?
my box is brand new, i mean it got hot and shut down, the car wouldn't run until i bypassed it. next time i hooked it up it fried. i'm in the process of getting another.
now wtf happened?? i mounted it there because you guys stated it was good there.
