Major Upgrades
Old May 2, 2007 | 02:42 PM
Altekameraden's Avatar
Major Upgrades
I have a 93 z28 automatic, and was wondering wat bolt-ons i could purchase first to achieve a large boost in hrp and tq before moving up to the engine boring and overhaul main considerations are
Header systems
Intake manifold and throttle body
performance chip
stall converter and tranny
camshaft
thanks in advance
Old May 2, 2007 | 03:48 PM
2000GTP's Avatar
A basic cold air intake and catback exhaust will be the easiest mods to free up some power.
Old May 2, 2007 | 04:00 PM
VK's Avatar
VK
Best bang for the buck would most likely be what 2000GTP said, along with some headers if you don't have to do emissions then you can run the Long tube headers which gain you the most power.
Any intake for the most part will work. Don't HAVE to get the ~150$ K&N one.
Same with the exhaust, you don't have to buy a borla.
Old May 3, 2007 | 12:54 PM
already have moroso cold air and magna flow catbak sys but there is a delay in throttle response that i dont like about 1-2 secs and it sounds like the engine wants to choke out and then my acceleration sucks
Old May 3, 2007 | 02:46 PM
FeelTheSpeed's Avatar
When was the last time your fuel filter was replaced? Fuel pump? Injectors? Because that is a fuel related problem.
Old May 3, 2007 | 02:47 PM
2000GTP's Avatar
Sounds like you have a mechanical fault with the car. Adding more mods isn't going to help that.
Old May 3, 2007 | 04:18 PM
tryintogofast's Avatar
Well a tune up first would be the best thing to regain some of the power you've lost. Plugs, Wires, fuel filter, any fluids that need it. Then my suggestions for other mods would be gears(3.73), subframe connectors,Lca's and then pacesetter longtube headers.
Mikey
13qtr
Oct 28, 2016 08:11 PM
David Dempsey
Mar 12, 2016 12:42 AM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
