Main and rod bearings in car
Old Jan 30, 2007 | 03:36 PM
  #16
buzz12586's Avatar
Originally Posted by rskrause
If you can do the cam bearing w/o pulling the motor, my hats off to you
Rich
The whole motor is being pulled out because it blew a headgasket. If the motor is out does it make sense to do cam bearings???
Old Jan 30, 2007 | 04:30 PM
  #17
Very much so.
Old Jan 30, 2007 | 04:32 PM
  #18
buzz12586's Avatar
Originally Posted by shoebox
Very much so.
What about the main bearings?
Old Jan 30, 2007 | 06:58 PM
  #19
MadaSnik84's Avatar
In an effort to keep this thread from going on for pages, just wanted to update that the bearings aren't going to be changed. There's no indication that there is a problem with them, it was just a "might as well while I'm in there" idea.
We have to roll in new bearing shells with the crankshaft in place on the diesel engines at work, but that's partly because you have to take the roof off the building to get the top half of the block off to pull the crank. But you can also check bearing clearance without removing the caps in an engine that you can crawl inside the crankcase of.
Thanks for the input.
LeftoverChinese
Jan 14, 2024 03:03 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
