Please help won't start.
Old Jan 30, 2007 | 12:49 PM
Angel_G_Z28's Avatar
my 1994 Z28 won't start i replaced the fuel pump yesterday and the damn thing still isn't getting any fuel, will some one please help
Old Jan 30, 2007 | 12:54 PM
95LT1conv's Avatar
can you hear the pump prime? did you replace the filter as well?
blazzen's Avatar
there is a small bleeder valve at the back of the fuel rail. press it and see if you have fuel pressure.
Old Jan 30, 2007 | 12:56 PM
no yeah i checked that and no pressure to the fuel rail at all, could it be the relay?
Old Jan 30, 2007 | 12:57 PM
and no u don't hear the pump prime,
Old Jan 30, 2007 | 01:10 PM
95LT1conv's Avatar
hten something is not right with the pump or a relay or fuse is bad
Old Jan 30, 2007 | 01:14 PM
fuel pump is brandnew outta the box
Old Jan 30, 2007 | 01:28 PM
95LT1conv's Avatar
did you change the filter? it is an electical device, sometimes you just get a bad one.
Old Jan 30, 2007 | 01:29 PM
95LT1conv's Avatar
it is also possible the relay could have been the problem the whole time
Old Jan 30, 2007 | 05:26 PM
i'll change the filter and the relay to, but wut if thats not it? could it be a short in the electrical system to the fuel pump?
Old Jan 30, 2007 | 05:30 PM
2000GTP's Avatar
The easy way of knowing would be to get a voltmeter and see if the connector to the pump is getting power. That will confirm whether the relay, fuse, or wiring are at fault.
Old Jan 30, 2007 | 07:53 PM
yeah my mechanic checked it out he said when i first turned the key there wuz power to the connector but now no juice, so u think it's the relay
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
