Main and Rod Bearing Question
Old Feb 23, 2007 | 08:07 AM
buzz12586's Avatar
I am probably going to have my stock crank turned during my rebuild which I believe means they will take material off of it to make it all smooth again. Now when I look at bearings they list them as stock or .10, .20, .001, etc.. UNDERSIZED. Does that mean they are actually bigger to make up for the undersized crank, or are the bearings themselves undersized??
Thanks.
Old Feb 23, 2007 | 08:13 AM
Chris 96 WS6's Avatar
No your first inclination is right. The bearings are oversized to make up for the corresponding reduction in size in the crank.
Old Feb 23, 2007 | 08:14 AM
buzz12586's Avatar
Alright cool. So they are simply talking about the crank being undersized. Makes sense. Thanks.
Old Feb 23, 2007 | 08:37 AM
SStrokerAce's Avatar
Ok the problem is did you spin a bearing? If so I'd just get a new crank, if not you don't need to turn it. You can get away with just polishing the journals. People don't realize that the labor to just turn a crank is just not needed today unless it's an expensive aftermarket piece.
Bret
Old Feb 23, 2007 | 09:17 AM
buzz12586's Avatar
No it just blew a headgasket. So if the crank itself is fine there is no need for it to be turned?? If the journals are polished will I need different bearings??
Old Feb 23, 2007 | 09:40 AM
New bearings need to be matched to the crank after it is polished.
Old Feb 23, 2007 | 09:41 AM
Mike96z's Avatar
Bearings are undersized for the material you take off, if you are having to turn the crank, you will surely have to get that block line bored and you will need a + size bearing to make up the difference you took off to make the things true again. Personally I wont use a block or crank that needs to be turned, if it is a high performance application you have a greater chance of spinning a bearing with a line bored block/turned crank. I say get a new crank atleast.
Old Feb 23, 2007 | 10:09 AM
Yeah all you need is to polish the crank then. That just takes new stock size bearings.
As for line/bore line honed blocks, as long as it done CORRECTLY it's actually better than stock. How do you think you install 4 bolt main caps?
Bret
Old Feb 23, 2007 | 10:16 AM
buzz12586's Avatar
Alright thanks Bret. I think I learn new things every time you post.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
