main cap stud questions
Old Aug 26, 2008 | 09:19 PM
lt1s10blazer's Avatar
i'm in the middle of my first engine build, i'm pretty excited but it's been to long since i've taken it apart and i've got some questions....... maybe i'll do a build up, iono?
when going to torque down the main caps. the 2 middle ones that are studs i don't have a deep socket long enough. do i j/need to find a longer socket or is there a special tool? and uhmm.. why are there threads at the end of the studs what goes on them? i cannot remember for the life of me... thanx
Old Aug 26, 2008 | 09:26 PM
Z28-YA's Avatar
You just need a deeper socket, and the threaded ends are for the factor windage tray.
Old Aug 26, 2008 | 09:32 PM
whats a windage tray? i see in the oil pan where it looks like those studs would stick in but i don't see what it would thread into there...like i said its been a while since i took it apart everything is fuzzy...
Old Aug 27, 2008 | 05:20 AM
The studs don't attach to anything in the pan. There is a piece of fairly flat sheet metal that fits over the studs. You can see it just above the oil pump pickup in this diagram (courtesy of Shoebox):
http://shbox.com/ci/oil_pan_bolts.jpg
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
