Mail order tune?
Old Apr 13, 2008 | 01:56 PM
scott5's Avatar
Mail order tune?
Can someone help with out with a mail order tune? How much will it help? I have u/d pulleys, no ac, LTs, and full exhaust with not cats, built tranny with 2500 stall, cai, 52mm tb.. do i really need one? OR should i wait till i get more mods? I am getting spray for it soon so should i wait or can i get updates?
Old Apr 13, 2008 | 02:02 PM
scott5's Avatar
i also have gears
Old Apr 13, 2008 | 02:09 PM
user 647483's Avatar
A mail order tune will gives you a nice boost in power even with a bolt on car.
Depending on the year, you can also tune to calibrate the speedometer for gear installs and adjust shift points
You can also delete codes (ie: emissions)
My personal opinion is that a mail order tune is #3 behind CAI and catback on the list of mods to do to a stock car.
You'll great a great product from Fastchip.com (Ed Wright), MadZ28 or PCMForless.
A dyno tune on the other hand is something you will want to hold off on.
There's really no point in spending that money for a bolt-on car.
Old Apr 13, 2008 | 02:11 PM
mrmint69's Avatar
Changing the gears will throw off the speedometer so that alone would make me get one. You should see some hp gains and they aren't that much so its up to you. They offer email tunes that are only $75 so if you have the cable and laptop thats an option.
Old Apr 13, 2008 | 03:59 PM
2000GTP's Avatar
With gears you will need a tune either way, might as well get a full mail order tune and add some power and improve some other things.
Old Apr 13, 2008 | 09:23 PM
Max Lewis's Avatar
I had done a few bolt on's on my car, and after using Data Master to data log it. I couldn't believe how much it would run rich to lean and back and forth. I used PCMFORLESS to tune my car and after installing the tune I data log it again and the car no longer run rich to lean and back and forth like it did before. For that reason alone it is worth getting a tune. There is nothing better than a efficient running car. Oh and the xtra power is nice too.
Old Apr 14, 2008 | 05:56 AM
scott5's Avatar
i was going to order this from Madz28.... Do i jsut tell them my mods and they send me what a new pcm?
Old Apr 14, 2008 | 06:27 AM
LJM97Z's Avatar
Either that, or you send them yours & tell them what you want, but if you get one from them first, there will be a core charge untill you send them yours.
Old Apr 14, 2008 | 07:13 AM
2000GTP's Avatar
Generally, that is how it works. You can send him your current PCM, that will result in a little more downtime though. He has an order form on his website where you fill in your mods and specs for your engine.
Old Apr 14, 2008 | 09:06 AM
scott5's Avatar
I put down all mods that i have that are gear and performance related? Not any thing like what kind of spark plugs or wires or anything like that?
Old Apr 14, 2008 | 09:29 AM
2000GTP's Avatar
No, he doesn't need to know about plugs and wires.
Old Apr 14, 2008 | 10:21 AM
Do you mean the O2 readings were jumping back and forth rapidly between rich and lean, in closed loop (part load/part throttle)?
Old Apr 14, 2008 | 06:46 PM
Max Lewis's Avatar
I meant my LTerm, and STerm counts. Which when you use the graph it shows the colors red as rich and green as lean. Now I am new to this so I could be wrong this is just what I have gathered from using Data Master here recently for the first time.
Old Apr 20, 2008 | 08:36 PM
scott5's Avatar
i have a hypertech on it now, do i need to take that off
Old Apr 20, 2008 | 09:12 PM
SS MPSTR's Avatar
put the base tune back into your PCM.
