MAF or speed density
Old Oct 16, 2006 | 02:05 PM
arod93z28's Avatar
I own a 93 z28 Lt1, so far all that is done to it is K&N CAI and a dynomax exhaust. I was wondering if the stock 93s were speed density or mass air.
If so is their a conversion kit (for highschool students with a low budget ) to make it mass air.
Old Oct 16, 2006 | 04:39 PM
WS Sick's Avatar
Re: MAF or speed density
The 93s are fine, to a point, They are harder to tune because of the removeable prom (chip). I had a 93 T/A for 8 years (93 to 2001) I also have a couple of chips that are burned for the different stages of mods I went through. The car seemed to respond well until I went with the longtube headers and a cam, after that it was very finicky with the tune.
The easiest way to goto a MAF system is an underhood harness from a 94 and a 94-94 ECM. With that you'll also have to of course get a MAF,heated O2 sensors, correct throttle body (the plug for the IAC is different) and switch around a few wires under the dash. If the car is an automatic you'll have to figure out a way to lock up the converter and get the speed signal to the ECM, or put in the appropriate 4L60E tranny, since the 93 autos were a non-electronic 5 pin 4L60 (700R4).
The 22 # injectors on the 93 will work with a tune, but if you don't tune it the world will not stop spinning, you'll just have to fiddle with fuel pressure to get it to run on par.
DirtyDaveW
Dec 1, 2016 05:37 PM
3TAS4ME
Apr 15, 2015 02:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
pete53
Dec 9, 2014 07:31 AM
Jul 4, 2005 05:00 PM
