MAF problem
Old Feb 16, 2003 | 03:59 PM
BAD BLACK WS6's Avatar
MAF problem
Ok, replaced my o2's and my plugs thinking it was causing the hesitation (real bad), because that was what it was last time. the header on the passenger side had worked its way loose, so i thought for sure i just smoked the o2's. well i bolted in the header, replaced the o2's and the plugs....still hesitating, and bucking in drive sitting at the light. so i looked at the MAF reading after all this trouble today and its sitting steady at 2.4 g. so the MAF isn't working at all. i know there is a fuse inline that may be blown (i had a small fire that burnt some wires and blew that fuse before)...also the unit may be no good. i just replaced it though about a year ago (the MAF)....so i think its a good unit. if the MAF was bad wouldn't i get SOME kind of movement on the scanner? also where the hell is the fuse for the MAF? if the fuse is good, i guess i just have to buy a new MAF and hope that is the problem. because it sure isn't working. i disconnected it, and it seems to run the same....but a little better. may just be chance, because plugged in or not plugged in it reads 2.4 steady.
Old Feb 16, 2003 | 04:05 PM
Fear The Z's Avatar
If the MAF was bad, you would get a SES light,
I dont think there is a fuse for the MAF.... I may be wrong, but never heard of one, you may want to check your wires and plugs out.....
Old Feb 16, 2003 | 04:12 PM
yeah, the plugs and wires are brand new and perfect. there is a fuse for the MAF, i burnt some wires on my headers and it smoked one of my o2's and burnt the fuse. i brought it in to GM because i couldn't figure it out. i know it was true because the MAF worked after it was back to me. i doubt they replaced the MAF for free and said it was just a fuse. its inline between the MAF and the computer somewhere, in a hidden place since in can't find it. although i may be wrong of course. also i have the computer retuned and i NEVER get SES lights for anything. also, last time the MAF was bad i got no SES light for it either.
Old Feb 16, 2003 | 10:32 PM
Peytons'z
May 6, 2021 09:25 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
3TAS4ME
Apr 15, 2015 02:24 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
