MAF Help
Old Jun 10, 2003 | 01:08 PM
MZK4252's Avatar
MAF Help
I just pulled a DTC 48 code, which is a MAF code. I tested the wiring as per the service manual and it indicates that the sensor is bad. Datamaster indicates that the AFGS runs about 17-60 (mostly ~17), but does not exactly follow engine RPM.
Symptoms are high idle and slight surges and slight power loss. I'm not sure exactly how the AFGS reading should behave, but I'd kind of like to make sure.
Any ideas? Time for a new MAF?
Old Jun 10, 2003 | 10:42 PM
MZK4252's Avatar
Anybody know anything about this...like what the AFGS should look like?
Old Jun 10, 2003 | 10:48 PM
Air flow grams/sec at idle will typically be 6 to 9gps. At WOT, 5800rpm, you might see 240gps. Have you seen my scanner writeup?
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
