MAF is good, but car only runs when MAF is unplugged
Old Jul 28, 2003 | 11:03 AM
BAD 97 WS-6's Avatar
My parents have a 94 Trans Am. Starter went bad on it and left me stranded when I was driving it. After numerous push start attemps, I could never get it started. We pushed it home and I replaced the starter the next day.
Well, the car would run like crap and cut off when first started. I then unplugged the MAF and it ran fine. I then bought a MAF off the board and plugged it in. Still acts the same. I then swapped the PC with a buddies car and still only runs when unplugged. What other sensor that is linked to the MAF sensor could be bad that makes the car only run in "limp mode"?
Old Jul 28, 2003 | 12:14 PM
Did you verify that the MAF sensor is getting +12V power to the pink wire on the connector? Seems to be a frequent problem where the wire gets damaged somewhere, and either breaks or shorts out.
Have you had it scanned for codes?
Old Jul 28, 2003 | 12:31 PM
Thats a good idea, I will check to see if that wire gets power. I don have a scanner for obd1
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
pete53
Dec 9, 2014 07:31 AM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
