MAF bad?
Old Jul 13, 2008 | 03:09 PM
NJLT1SS's Avatar
MAF bad?
OK, just got the car back together after doing a single plane conversion. I have everything hooked up, and the car cranks, but barely fires. It will fire if I hold the throttle down, and it will idle at like 1500 RPM’s belching tons of smoke out of the tailpipes. With the MAF disconnected, I got the car to run and idle. So with the car running on its own for like 5 minutes, I decided to plug in the MAF while it was running. Two seconds after I did this, the check engine light went out, and the car died. I had my laptop and scanning software hooked up, and the MAF was reading 486 GPS. Is this a sign that it’s dead?
Nick
Old Jul 13, 2008 | 04:43 PM
WS6T3RROR's Avatar
Check your wiring harness, 486g/sec is about where the stock maf tables max out. You may have a short or a bad ground or something in the maf harness. Or you could be right and the maf could be screwed.
Old Jul 14, 2008 | 02:06 AM
NJLT1SS's Avatar
Looks like Im ordering a new MAF tomorrow. I just took it off the car, one of the resistors is ripped off between the two poles. Oh well, at least I know its that for sure. Where is everyone ordering their GM parts nowadays? I used to go through Dal, but he retired last year.
Nick
Old Jul 14, 2008 | 05:51 AM
Have you checked the MAF harness connector for bent or damaged pins? Also check the pink wire to insure it has 12V when measured across the black/white wire in the connector. A broken pink wire is not an unusual problem on the 97's. You will get a reading like that with an open circuit. Have you checked it for codes?
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Old Jul 14, 2008 | 09:02 AM
NJLT1SS's Avatar
Injuneer, I checked the connector harness and it looked fine, no broken pins or corrosion. At the time it wasn’t throwing any codes. I was going to further look into the harness and check for a broken wire, but that’s when I discovered the broken resistor between the two poles in the MAF. I will be ordering a new one today.
Nick
Old Jul 14, 2008 | 09:10 AM
WS6T3RROR's Avatar
Just go to the scrapyard and get one from an ls1 or lt1 in the yard. I wouldnt put up full price for a new one.
Old Jul 25, 2008 | 05:35 PM
NJLT1SS's Avatar
Car runs great with the new MAF. Now a new problem has risen. Every time I hit a decent bump, the car stumbles. I get home, and I have the car idling in the driveway. I go to check the MAF plug, and when I go to touch it, the car dies. Looks like I have a break in the wire by the connector. Anyone know where I can order a new MAF plug and connectors?
Nick
Old Jul 25, 2008 | 09:47 PM
You mean the harness side of the connector and a few inches of wire? Get the part # for the pigtail off Shoebox's list and try a local parts source:
http://shbox.com/1/Parts.htm
Old Jul 26, 2008 | 12:35 AM
WS6T3RROR's Avatar
Ebay usually has them along with several other pigtails listed.
Old Jul 27, 2008 | 11:25 AM
flyinZ's Avatar
Id get ahold of Jason..He should be able to help you out, or if nothing else pick up a used one at a junkyard. But Id think you should be able to find one.
Old Jul 27, 2008 | 02:40 PM
NJLT1SS's Avatar
Jason? How do I get a hold of him? There are a few auctions on Ebay for MAF pigtails using factory wire and ends for like 10 bucks. Looks like I will be ordering one tomorrow.
Nick
Old Jul 27, 2008 | 05:21 PM
I think he means:
Old Jul 27, 2008 | 05:53 PM
flyinZ's Avatar
Yessir, Fred is correct.
I should've been clearer on my post.
Peytons'z
May 6, 2021 09:25 AM
SpeedJunkee
May 3, 2015 08:49 AM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
