MAD 6AL efficient?
Old Sep 28, 2005 | 10:25 AM
Myxtreme1's Avatar
MAD 6AL efficient?
Will the 6al help out with effieciency? Does it really help to completely burn all the fuel? I am probably going to install it and the MSD coil as well. What does it help besides the rev limiter? Thanks!
Old Sep 28, 2005 | 10:36 AM
Re: MAD 6AL efficient?
The stock ignition adequately provides for the needs of a relatively stock setup. With a power adder - nitrous or a blower - it needs some help and the MSD will provide what's required.
The MSD won't do much as a rev limiter, unless you set it below the stock PCM limiter, or have the PCM limiter raised above the limit you want to set in the MSD.
Old Sep 29, 2005 | 09:44 PM
Myxtreme1's Avatar
Oh thanks. Motors not stock and we built it with nitrous in mind so I will consider getting one later on. The main thing I am wanting is something to help burn the fuel more completly.
RX Speed Works
Sep 11, 2015 03:31 PM
NewsBot
May 29, 2015 01:40 PM
Drtryder
Apr 22, 2015 04:17 PM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
jayman350
3rd Gen / L98 Engine Tech
9
Mar 10, 2004 03:50 PM
