Machining question per 6.0 rods?!?
Old Oct 12, 2004 | 09:43 PM
Silvershark's Avatar
Question Machining question per 6.0 rods?!?
I was just curious if there was any special machine work required if I decided to go with 6.0 rods instead of the 5.7 rods.
I was looking at SBC Chevy 6.000" Eagle SIR 5140 Steel I-Beam Connecting Rods. Press fit pins.
And if not, is there anything required to do differently than the 5.7's?
Thanks.
Old Oct 12, 2004 | 10:10 PM
chy20k1's Avatar
Re: Machining question per 6.0 rods?!?
i dont believe there is any machining, but you do need differant pistons for 6" rods
Old Oct 12, 2004 | 10:16 PM
Really? I thought you could interchange the rods with whatever pistons you would like within reason. IE: the 6.0 rods with the forged pistons that come with the summit kit, or 6.0 rods with SRP pistons or JE etc...?
Maybe I am more lost than I thought. I thought as long as the dish size was made for you engine's cylinder walls it would be fine. The longer the rod the less wear and tear on the rod because the stroke isnt so long.
The only two things I have to worry about are the piston height so I do not go too far up in the cylinder wall and the valves hit the piston.
And then I have to make sure that the piston overall width is spec per the bore size.
Please someone correct me or fill me in on what I am mis-interpeting.
Old Oct 12, 2004 | 11:25 PM
ttt...
I dont wanna pass up a good deal.
Old Oct 13, 2004 | 12:16 AM
Spinner's Avatar
Well, a 6 inch rod is going to travel 0.3 inches more up the cylinder then a 5.7 inch rod. Thus, you need a piston made for that rod.
Old Oct 13, 2004 | 12:23 AM
Thanks spinner.
I am actually speaking with Frank from gofastparts.com right now trying to decide which route I want to go. 6.0 would give me a little more compression correct? So instead of 10.4 it would be closer to 11? I am looking for as much possible since this is gonna be a N/A beast.
Also he is suggesting the hypereutectic piston kit that he sells for 700 and some change.
I just want to make sure I am not gipping myself on the rods/pistons for a 400 HP N/A motor. But if the hypereutectic pistons will work I defiantly dont want to spend more on something I wont need.
Old Oct 13, 2004 | 12:26 AM
Spinner's Avatar
Compression is going to depend on the piston. Hyper pistons are fine for a N/A motor, but forged pistons are cheap insurance IMO ($250 more)
Old Oct 13, 2004 | 12:31 AM
Yah, he sells the 383 version kit of what I want to go with for my 355, however I want to stick with the 355 due to clearancing issues with the 383 which causes much more needed parts.. Well, it may not, but I would want to make sure I did it right and would purchase the other personal insurance parts for my own mind sake.
http://cgi.ebay.com/ebaymotors/ws/eB...926202278&rd=1
Maybe they make this in a 3.48 stroke.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
pimpss96
Feb 12, 2015 01:28 PM
Hurin
Dec 13, 2014 07:38 PM
1LEThumper
Jul 14, 2003 12:45 PM
