MAC Header Spark Plug Access Pics
Old Jun 13, 2004 | 10:52 PM
  #16
MikesGreenZ28's Avatar
how was the fitment of the header itself? does the coating stand up on them?
Old Jun 13, 2004 | 11:05 PM
  #17
stereomandan's Avatar
Originally posted by 96speed
I have always recommended the Macs as the best bargain header.
AS&M are the best midlength, and ofcourse LTs are a winner. However, Macs are decent quality and can be had for a good price.
Ryan
That's cool.
To be honest though, depending on what type of TQ curve you are looking for, the MAC's might be better, or the RKSports might be better. I wanted the better low end TQ that the MAC's get you, since I drive my car 50 miles per day and value the daily driving as well as the great performance.
AS&M's have the potential to get more HP, but you need an engine that requires the extra flow that a 1 3/4" primary can get you. The MAC's have shown better gains than 1 3/4" LT's with equal heads/cam packages.
Dan
Dan
Old Jun 13, 2004 | 11:06 PM
  #18
Blownbird355's Avatar
Can also get mine frrom top without removing anything, fat hands and stubby fingers Coating sux but, nice headers. Coating down low comes off first. Plus welds are kinda impeading flow, alot of people gind the flange welds down on the inside. and some re-weld outside and grind farther but no probs here with just grinding.
Old Jun 13, 2004 | 11:07 PM
  #19
The fitment was great. I bought mine from www.jet-hot.com which included the great Jet-Hot coating. They were $540 shipped to my door, for the headers and Y-pipe, coated inside and out.
There was one area that I decided to grind my front crossmember slightly, but I don't think it was necessary. The fit was great.
Dan
Old Jun 13, 2004 | 11:25 PM
  #20
1badasZ's Avatar
can you run true duals with the mac headers since they are mid length headers? and would i see a gain swapping to those from the edelbrock headers cause i have a buyer if so
Old Jun 14, 2004 | 12:35 AM
  #21
Rich_z28's Avatar
Yes, you can run true duals off of MACs. There is a company from Texas (i believe) that makes a kit for them. Or you could fab up your own. But the answer is yes.
Old Jun 14, 2004 | 01:04 AM
  #22
1badasZ's Avatar
anyone know who the company is?
Old Jun 14, 2004 | 01:39 AM
  #23
disco192's Avatar
Lanes, its in dallas.
540 i think for true duals dumped at the axle.
Old Jun 14, 2004 | 10:54 AM
  #24
FireHawk409's Avatar
What does that 540 consist of?? I already have macs and i was thinking of going with a true dual setup if the price is right. Does Lane's have a webpage or phone#??
Old Jun 14, 2004 | 11:22 AM
  #25
disco192's Avatar
Dan you should work for MACs. You have nothing bad to say about these, it cracks me up.
And about the thouht of 1 5/8 LTs, the main reaon that they havent done that is because there is more to designing a header than just backpressure provided by the main tubes. The main advantage of long tube headers is the equilization effect that takes place due to equal length runners (some are).
When you determine what RPM you want the headers to run best at, you will need to take into consideration primary tube length and diameter. If you go Long tubes and 1 5/8 primaries, then it would change the RPM band......
Just thinking out loud. I have macs and like them. Need to get them coated though.
Old Jun 14, 2004 | 11:23 AM
  #26
truedualws6's Avatar
Dan,
Great pictures and much appreciated. I will save them for my
"maybe in the future" file. I am still not ready to give up on
the cast iron exhaust manifolds, especially since my long range
plan is a baby cam.
FireHawk409,
As for true duals with mids, it should be no problem at all to
go all the way back over the axle w/ 2.5" pipes. The way to do
it is to route the pipes on the passenger side just like the stock
configuration. If you want quiet, use an Ultraflow or Magnaflow
muffler. Dumped at the axle with bullets is waaaaay to loud and
probably stinky as well. If your only consideration is cheap, then
the Lane's route dumped a the axle is the way to go.
Old Jun 14, 2004 | 11:36 AM
  #27
Well, there is one bad thing that I can say. I had a pretty large leak in the drivers side collector that I had to have welded up. It was poor welding from MAC. Also, the welds inside the primaries, closest to the heads, were not that great and I gound them down a little.
I know I sound one sided, but after studying how headers work, MAC's were my obvious choice. When I joined this board, whenever someone asked about headers, the automatic response was, " Get Long tubes, they are the best" or "You will regret getting anything other than LT's" I'm a mechanical engineer by profession and it's part of my nature to over analyze things. When I started to look into header theory, I quickly found out the LT's were not for me. I would rather have a 1 5/8" primary LT header than a 1 3/4" LT header. I would also rather have a 1 5/8" midlength header than a 1 3/4" midlength header, like the RKsports or SLP's. The 1 5/8" primaries help a lot with good low end TQ compared to 1 3/4" because of exhaust scavenging. Also, when I see the same heads/cam packages making equal power at 400 rwhp with both MAC's and LT's, it lets me know that I'm not going to outgrow my MAC's, since I don't even plan on making that kind of rwhp, but it shows that the MAC's can handle it, no problem.
I just want the header arguement to be more scientific, instead of just taking someones word for it.
Dan
Old Jun 14, 2004 | 12:27 PM
  #28
disco192's Avatar
I hear what you are saying. I think the 1 5/8 primaries for the mids are better too because they do act like a longer tube because of scavenging like you said. The bigger the tubes, the longer they need to match the scavenging RPM. Thats why almost all 1 3/4 are long tubes.
Dan, remember the argument we had about HP vs TQ... that still cracks me up to this day.
Old Jun 14, 2004 | 12:41 PM
  #29
Mystic95Z's Avatar
The SLP Single Cat 1-3/4's arent that bad when you use the right tools. I can do all of mine from the top in ~45min to 1 hr using a shortened & drilled socket and ratcheting end wrench.
-Tony
Old Jun 14, 2004 | 07:10 PM
  #30
do you have the part number for the ones you ordered? the jet-hot site only lists shorty macs for 94-95
Does the Y-pipe attach to the cat or does it delete it?
