Mac header people in here...
Old Jan 19, 2004 | 04:56 PM
z28marine's Avatar
Who has a problem with the steering linkage rubbing on the driver side header? Mine is right up against it, so im getting a constant vibration and rubbing noise whenever i drive. Anyone know a way to fix this?
Old Jan 19, 2004 | 05:01 PM
Brandon 95 Z28's Avatar
Hmm, mine doesnt even seem to be that close to the steering linkage, what is rubbing, the slip tube?? What gaskets are you using?
Brandon
Old Jan 19, 2004 | 05:53 PM
Larnach's Avatar
I had the exact same problem dude, I ended up grinding the steering shaft a bit and now its perfect.
That's the only way I can think of, my motor mounts are brand new too.
Old Jan 19, 2004 | 05:56 PM
94ZGRNMCHN's Avatar
Mine fit just fine,no issues at all with the steering shaft.Not sure what to tell you.
Old Jan 19, 2004 | 06:03 PM
bigde4u's Avatar
Mine only rubbed the plastic cover around the linkage, that was it and i just took the plastic off.
Old Jan 19, 2004 | 07:31 PM
Laymaster's Avatar
do you mean the plastic thing is rubbing? i ripped that right off, you don't need it.
Old Jan 19, 2004 | 08:34 PM
b-stevens's Avatar
Do you have pics of where its rubbing?
Old Jan 19, 2004 | 08:52 PM
Fast Caddie's Avatar
Ditto on the above, i took the plastic thing off and there's at least 2 or so inches between the shaft and the primary. If it's hitting the shaft then it's probably best to send that set in and get another one
Midnight_Z
Feb 16, 2016 09:36 PM
Zpower
Sep 18, 2002 05:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Fusion93Z
Sep 10, 2002 06:46 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
