AS&M Install Question?
Installing the number 1 primary on the drivers side, it says to use "Anti-Seize"? It didn't come with any, what should I use? I have lock-tite would that work (Red)? Any suggestions would be greatly appreciated. Thanks to all those who reply.
Thanks Again
Tuff.
Thanks Again
Tuff.
Don't use lock-tite. Go to the parts store and get some anti-sieze. Put the anti-sieze on the number 1 tube when you slide it into the header pipe. It helps you get it all the way down, so you can bolt it up to the head. Also, use the anti-sieze on the header bolts and get some stage-8 1 inch header bolts if you can. Those things work great.
Tuff.
Chrisdude
Jul 24, 2002 02:25 PM
