AS&M Install Question?
Old Jun 26, 2003 | 09:34 AM
Onetuffride's Avatar
Question AS&M Install Question?
Installing the number 1 primary on the drivers side, it says to use "Anti-Seize"? It didn't come with any, what should I use? I have lock-tite would that work (Red)? Any suggestions would be greatly appreciated. Thanks to all those who reply.
Thanks Again
Tuff.
Old Jun 26, 2003 | 09:44 AM
Blk94Z28LT1's Avatar
Don't use lock-tite. Go to the parts store and get some anti-sieze. Put the anti-sieze on the number 1 tube when you slide it into the header pipe. It helps you get it all the way down, so you can bolt it up to the head. Also, use the anti-sieze on the header bolts and get some stage-8 1 inch header bolts if you can. Those things work great.
Old Jun 26, 2003 | 09:51 AM
Thanks for repling, one question does the anti-seize keep from leaking out of the number one primary? I was afraid of the exhaust leaking out of the number primary. Thanks for your help.
Tuff.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
