Lunati timing chain set questions
Old Feb 27, 2009 | 07:40 PM
andysc's Avatar
Hi there
Saw this on ebay but went to summit's website and found this. http://store.summitracing.com/partde...w=1&N=700+150+.
Does anyone use this, and is it complete as in does it need a gear for the waterpump or is it allready there. Can't tell from the photo. I realize the gasket kit is extra, but summit has it for about a hundred dollars less then jegs. Any feedback on this would be appreciated. Mine is stock and has 205k on it, so I believe its time to change it. May not stretch as much as the factory one does. Let me know
tia
andy schuck
Old Feb 27, 2009 | 10:14 PM
Every time I look at the picture of that set, it looks just like a stock GM set. It even has the GM stamping on the cam gear.
Old Feb 27, 2009 | 10:15 PM
user 647483's Avatar
I use the Lunati on my builds as well, they're identical to the to original set as far as I can tell.
Works with stock waterpump and timing cover. (also works with EWP)
Note that the set you posted is listed for 92/93 LT1 motors.
I never understood why they don't think it fits a 94.
Old Feb 27, 2009 | 10:21 PM
Note that the set you posted is for 92/93 LT1 motors.
...or 94s, since we are talking f-body.
andysc: That is the correct set and has the w/p drive teeth.
Old Feb 27, 2009 | 10:42 PM
andysc's Avatar
thanks for the replies. For the price you can't beat it. I was looking for something stock, so a set from gmpartsdirect.com
was slightly more, mostly for shipping as usual. I just didn't want to buy it, then find out I needed to get something else.
thanks again
andy schuck
Feffman
Oct 9, 2015 05:42 AM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
