LT's cause me to run rich?
Old Apr 26, 2004 | 01:24 PM
drewstealth's Avatar
I just got my Hooker LT's installed about 1 1/2 weeks ago. It sounds like i have a exhaust leak somewhere. When i dyno'ed my car i was running very rich. I was in the low 11 a/f ratio to mid 10 a/f ratio up top. I know i should be somewhere around 13 a/f at wot. I'm gonna go ahead and get a mail order tune on my car. Will that fix my problem of running so rich? When you go from manifold to LT's will that cause a car to run rich?
Old Apr 26, 2004 | 01:32 PM
Exhaust leaks before the O2 sensors can cause a rich condition. Misfires from burned wires can cause a rich condition. Poor quality sensor extensions, if used can add to the problem. It isn't the LT's that cause the problem, its the problems associated with the install that can cause it.
Old Apr 26, 2004 | 03:32 PM
Okay now i see. Thanks for the help. Its really hard to find out why my car is running so rich. I checked all the wires and they look good and none of the cylinders are misfiring when i scanned it. I hear a ticking sound so i know there is a leak somewhere but i don't know how to figure out from where it is coming from.
Old Apr 26, 2004 | 04:09 PM
Cmr0z28's Avatar
Use a small piece of vacuum hose to check for exhaust leaks. It's probably a leaking header or collector gasket.
Old Apr 26, 2004 | 04:13 PM
LWillmann's Avatar
How do you use a small piece of vacuum hose to check for exhaust leaks?
My car developed a tick after the install, and it was a loose plug.
My car is also adding a lot of fuel when cruising, but I can find no exhaust leaks.
Old Apr 26, 2004 | 04:19 PM
Pasky's Avatar
Put one piece to your ear, the other to the suspected spot. Ta da!
Old Apr 26, 2004 | 04:45 PM
I noticed right above the #1 primary on the top of the gasket it is a little brown. The gaskets i used are percys dead soft aluminum
Old Apr 26, 2004 | 05:53 PM
Cmr0z28's Avatar
There's your problem
Old Apr 26, 2004 | 06:18 PM
well that sux i don' t wanna have to put a new gasket on the thing
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
