LTs on a 95 w/flowmaster catback.
Old Feb 18, 2004 | 01:30 PM
Valkyn71's Avatar
Anyone have any info on how i would do this? I imagine i would need to have a custom Y-pipe made to go over to the cat? (which i would like to keep)
Remember the cat is under the passenger seat, so the Y-pipe would have to run over to the right.
Anyone forsee any clearance problems or any problems for that matter.
Thanks!
Old Feb 18, 2004 | 06:09 PM
Valkyn71's Avatar
ttt can anyone help me out
Old Feb 18, 2004 | 06:18 PM
SlickBlack Z's Avatar
You wont be able to run long tubes into your cat where it's currently located. If you want to keep your cat there, go with the SLP system(or similar) for 93-95 cars. If you want long tubes, why not consider a dual-cat y-pipe setup that runs into your cat-back?
Old Feb 18, 2004 | 06:21 PM
Violat0rX's Avatar
What kind of long tubes are you getting? Also, does your year car have the dual cat setup or the single from the factory? Cuz mine is a '96 and i'm pretty sure it had 2 cats, both of them i think were on the passenger side. I could be wrong about that tho. But I got FLP long tubes installed, and it came with a y-pipe that had 2 cats, but one cat is now under the driver side. I know random tech sells a dual cat ypipe, I don't know which headers they will bolt right up to tho. I hope this helps a little.
Old Feb 18, 2004 | 06:22 PM
Valkyn71's Avatar
Im not opposed to moving the cat, but i would like to keep it.
Reason im asking this stuff is the flowmaster inlet is over the passenger side axel, so a Y-pipe is gunna have to run over that direction, and im not sure if it can be done without loosing alot of ground clearance.
I dont have the car near me currently, and im bored so just trying to work things out.
Old Feb 18, 2004 | 06:26 PM
Clarification:
On single cat cars---the cat is under the passenger seat floorpan.
On dual cat cars---one cat is tucked up next to the engine on the driver side, and the other is under the passenger seat floorpan.
Old Feb 18, 2004 | 06:29 PM
Valkyn71's Avatar
Sorry missed one post.
Yes car is a single cat setup from the factory. With that cat being under the passenger seat area.
Old Feb 18, 2004 | 06:30 PM
The FLP long tubes come with a y-pipe and 2 cats that will bolt up directly to your existing cat-back. Other brands (jet-hot, hooker) require a custom y-pipe. You will lose a little ground clearance on the driver side because the pipe has to clear the trans crossmember... but if your car is not lowered, its not much of a concern.
Old Feb 18, 2004 | 06:32 PM
Valkyn71's Avatar
Erg, im looking at putting in Jethot LTs.
So it wouldnt be too much of a problem to have a custom Ypipe made to work with my Flowmaster?
Thanks guys
BadBwty
Feb 18, 2003 05:26 PM
whitelightnin
Aug 2, 2002 11:53 AM
whitelightnin
East South Central
29
Aug 1, 2002 10:40 AM
Fusion93Z
Jul 13, 2002 01:02 PM
COOPS89IROC
3rd Gen / L98 Engine Tech
Jun 17, 2002 06:58 PM
