LTCC grounds
Old Dec 20, 2004 | 11:23 AM
Eff's Avatar
Eff
LTCC grounds
One of the first things I saw when I open the box for my LTCC conversion was the warning about needing good grounds. My question is, I plan on grounding the ground wire on each of the coil primary wires. buy does the coil itself need to be grounded?
The bracket setup I will be using will mount to the valve covers and most likely will not be very well grounded. Should I worry about grounding out the coils themselves, or will the provided grounds be enough?
Old Dec 20, 2004 | 11:41 AM
94 NO TOP Z's Avatar
Re: LTCC grounds
I have the coils mounted on top of the valve covers which I guess provides all metal to metal contact and a good ground. I even have a few of the wiring harness grounds to the same mounting points and I haven't had any problems in the two years I've been running the LTCc.
Old Dec 20, 2004 | 12:12 PM
crash4cyl's Avatar
Re: LTCC grounds
I ran a setup that looks like the corvette rail covers, made of sheet metal. It attached at the fuel rails and I grounded 2 coils per bolt of the fuel rail...It worked fine and never had an issue...But I would most definately ground the coils, or you'll run into an issue with them either not firing or firing really weakly.
Chris
Old Dec 21, 2004 | 10:52 AM
"White Knight"'s Avatar
Re: LTCC grounds
what is the LTCC?
Old Dec 21, 2004 | 11:38 AM
Re: LTCC grounds
http://www.bailey-eng.com/
Old Dec 21, 2004 | 12:30 PM
Mikey97Z's Avatar
Re: LTCC grounds
I think you just need to ground the wires from the coil connectors, not the coil body itself.
95chwagon
Oct 16, 2015 12:24 PM
autoxr166
Sep 25, 2015 04:21 PM
Greg88
Sep 20, 2015 07:14 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
92_RS_305
Sep 8, 2015 07:47 PM
