LTCC coils mocked-up
Old Jan 26, 2015 | 09:20 AM
maybe2fast's Avatar
I picked up an extra LT1 over the weekend that will sit in the corner of my garage...probably forever, or until I need a rebuild. I have ordered my LTCC and decided to use my new engine for coil ideas.
This is the LS2 coils installed onto the Proform coil brackets. I originally wanted to use them like a fuel rail cover, but I discovered a new idea.
Going to pick it up, I was at my buddies house (Darth Vader house in the background)
Got it into the garage
Tearing it down...looks like a newer opti, and a MSD Blaster coil
Starting the mock up
Old Jan 28, 2015 | 07:02 PM
mikey4play's Avatar
Re: LTCC coils mocked-up
I like your idea but better double check you have enough clearance with the HVAC box.
Old Jan 29, 2015 | 08:35 AM
maybe2fast's Avatar
will do!, I will see what they look like in the car!
Old Jan 29, 2015 | 09:59 AM
Alternative approach, particularly useful when running a solid roller cam, requiring more frequent removal of valve covers.....
Out of sight, out of mind.
Old Jan 30, 2015 | 08:05 AM
maybe2fast's Avatar
I bet I can get those brackets to bolt nicely under there too!
Old Jan 30, 2015 | 10:17 AM
Don't use the "bottom" location on a supercharged setup.... broken belt tears the wires out.
Old Jan 30, 2015 | 09:22 PM
97WS6SCharged's Avatar
I never broke a belt with any of my blower setups. Made plenty of dust with the YSi though.
Old Jan 31, 2015 | 12:56 PM
My only experience is seeing the aftermath of the belt letting go on George Baxter's 9.0-second 30th SS convertible. We were both running the same coil setup with the MoTeC ECU. But that's all ancient history, dating back to maybe 2002.
Old Feb 1, 2015 | 02:43 PM
mikey4play's Avatar
I am going to try something like this. Got the rings burnt out at work just need to mock up the coils.http://i1243.photobucket.com/albums/...ps6f204537.jpg
Old Feb 5, 2015 | 05:14 AM
I usually advise against mounting them to the valve covers or to fuel rail covers as I originally did. It looks nice but if you have to adjust the rocker arms it's a hassle.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
