LTCC coil conversion crank but no start
Old Nov 13, 2022 | 02:30 PM
Chrisgags0116's Avatar
hey guys I just installed the LTCC swap kit on my 96 firebird formula. The first box I had ran great for two days but got moisture in the box. Once this happened the car started terribly misfiring and now 3 cylinders are dead. I had gotten a replacement box and when I plug it in it cranks but no start and I have 4 blinking red lights. I tried plugging in the old box and it runs except 3 cylinders are still dead. Anybody have any ideas?
Old Nov 13, 2022 | 04:46 PM
Re: LTCC coil conversion crank but no start
4 blinks = a problem with the spark signal from the PCM. Check the white wire.
See page 5 LTCC of instructions.
https://www.camaroz28.com/forums/lt1...ctions-882760/
Checking white wire from PCM:
4th Gen LT1 F-body Tech Articles
Old Nov 13, 2022 | 07:21 PM
We haven’t changed anything from the setup when we got the new box. None of the wires where touched. It runs with the crappy box, but not with the new one
Old Nov 13, 2022 | 09:39 PM
Do you get 4 blinks on both boxes?
The white wire from the PCM is firing the ICM based on the low resolution pulse signal from the Opti. When the LLTC box suffered from water intrusion, did other parts of the engine as well?
When in doubt, contact Bob Bailey. May take a while for him to respond. Buddy of mine who’s reinventing my old Formula recently had a problem with a box and Bob solved the problem.
Old Nov 13, 2022 | 10:50 PM
The other box runs and there are no flashing lights. I think the new box he sent me could be defective I’m not sure.
Grims
Nov 27, 2006 10:45 AM
hot95camZ28
Oct 5, 2005 06:34 PM
hemigtx001
Jun 24, 2005 06:31 AM
jrutland
Dec 26, 2004 08:36 PM
95_RipperZ
Jul 15, 2003 07:47 PM
