Ltcc
Old Mar 25, 2005 | 09:03 AM
Dave19yz28's Avatar
Ltcc
Did a search, but didn't really find what i was looking for...
How many guys in here are running the LTCC setup? I'm thinking of going this route and was wondering how hard the install was, and how it's working out for you. Thanks.
Old Mar 25, 2005 | 10:04 AM
Beyonce Knowles's Avatar
Re: Ltcc
sorry for the hijack, but that is an LTCC? Long Tube Comp Cam? Lowered Traction Counter Clockwise?
Old Mar 25, 2005 | 11:10 AM
Inutero's Avatar
Re: Ltcc
ehh I think it's a type of ignition system
Old Mar 25, 2005 | 11:25 AM
arnie's Avatar
Re: Ltcc
Either you didn't search very well, or thread(s) have since been deleted from archive. Not unlike the efforts of others, alot of typing went into that subject matter. Anyway.....
The LTCC or LT Coil Converter works well, in my experience. Smoother idle/low rpm with high rpm performance gain dependant on need based on combustion pressure increase.
It is necessary to design/fabricate your own LSx coil mounting brkts and decide on location of same.
Old Mar 25, 2005 | 11:56 AM
Shon Herron's Avatar
Re: Ltcc
I used it on my 94 car and loved it. Has alot of built in features that are really nice, like a 2 step or a timing retard.
I am considering getting one for this 97 for the 2 step function.
The only thing is mounting/placing the LSx coils in a way that is not 'ugly', I had mine on the firewall but would not do that again, too hard to get to.
Old Mar 25, 2005 | 05:47 PM
bdc95ta's Avatar
Re: Ltcc
I've had no problems w/ it but every once in a while I wonder if I really needed it?? The stock system is/was adequate...it came down to (for me) my opti. crapped out and I didn't what to ever have to mess w/ it again so what could I do...LTCC. But for the price I spent (roughly $800 I think) I'm not sure if it's worth the cost....
-brandon
Old Mar 28, 2005 | 11:06 AM
Dave19yz28's Avatar
Re: Ltcc
My serach yielded the same thing you guys are saying, most people that lgot it love it...but is it really necessary?
I was just wondering how the install went, is it really just a "plug n' play" sorta thing. As for the mounting brackets, MBA (one of the sponsors on this site) makes a nice litte mounting that that looks great. Thanks guys
Old Mar 29, 2005 | 12:43 PM
Dave19yz28's Avatar
Re: Ltcc
I was just wondering how the install went, is it really just a "plug n' play" sorta thing. What needs to be done with the opti? As for the mounting brackets, MBA (one of the sponsors on this site) makes a nice litte mounting that that looks great. Thanks guys
Old Mar 29, 2005 | 03:38 PM
bdc95ta's Avatar
Re: Ltcc
install was fairly straight forward, the MBA brackets do look nice, wish I would of gone that route now. I ended up use one of the ls1 brackets for the dr. side and some custom alluminum one's for the pass. side. Someday when I have some extra time I'll make a matching brakets for the dr. side.
About the opti. the pig tail that connects by the map sensor needs to be uncliped & connected to the ltcc wiring. Then the other end connects to the other connecter on the ltcc. Your basicly rerouteing the info. to the ltcc before going to the pcm. Your Coil comes completely out and depending on the year (diff. colors for diff. years) you have to cut and crimp some connections down there. And that's it!! Not much to it.
-brandon
Old Mar 29, 2005 | 04:05 PM
Dave19yz28's Avatar
Re: Ltcc
awesome, exactly what i was hoping to hear
In the event that my opti is in fact shot...and i put this LTCC kit on, the only reason it wouldnt work is if the rotor in the opti somehow wasnt at the right poisition, or had fallen off, since it's no longer being used to generate the spark?
Old Mar 29, 2005 | 04:23 PM
slverbullet's Avatar
Re: Ltcc
the ltcc will still work because of the sensors in the optical part of the opti will still be sending the computer information. that is provided that the sensors themselves are still working properly. if the opti itself is not set on the cam correctly, then no, the ltcc wouldnt work correctly until the opti is set in its proper position on the camshaft. if the rotor is broken or whatever, it will have no bearing on the ltcc working properly.
Old Mar 29, 2005 | 04:27 PM
Dave19yz28's Avatar
Re: Ltcc
ahh ok...thanks for all your help guys, just one more question, what plug wires are you guys running with this setup, looks like the LS1 wires won't fit correct? Having said that i would assume i will need to make my own, what style boot plugs into the LS1 coil packs?
Old Mar 29, 2005 | 04:52 PM
Dave19yz28's Avatar
Re: Ltcc
woops, nevermind guys got it all figured out thanks for your help
Old Mar 30, 2005 | 09:27 AM
bdc95ta's Avatar
Re: Ltcc
I'm running a washer and magnecor wires.
Old Mar 30, 2005 | 03:49 PM
arnie's Avatar
Re: Ltcc
Quoting myself......
.....high rpm performance gain dependant on need based on combustion pressure increase.....
What does that mean or imply? Without extensive mods, (especially FI) don't expect any gain, as added spark intensity isn't needed. In and by itself, increased spark does not increase hp/torque.
Injuneer
Apr 25, 2022 06:22 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Lt1son
Jul 8, 2015 08:46 AM
RobZ
Aug 1, 2003 04:48 PM
