LT4 Valve cover question.
Question. I have seen talk of a vacuum pump that attaches to this portion of the engine to increase piston ring sealing, and possible HP gains of 10-15. If the increase in vacuum would increase power in this manner, how do the breathers work?
The connection with the throttle body is to let MAF metered air into the crankcase for the PCV system to suck it back out again and the engine burns it, so it is just an air supply. When you are making more pressure in the crankcase than the PCV system can handle, like on a blown engine, then you might need more breathing than the stock PCV setup can provide.
