LT4 Timing chain
Old Feb 11, 2004 | 04:01 PM
1BadBrd's Avatar
LT4 Timing chain
I'm stepping up to the GM847 Cam. 234/242 with some lift close to .600.
I already have the lt4 timing chain, will this timing chain be okay. Some guiy mentioned its junk and i should upgrade to cloydes dual chain.
Any advise on this info?
Old Feb 11, 2004 | 05:14 PM
NC-Chris's Avatar
Highly recommend a Double roller Cloyes. We had an LT4 chain break after installing the hot-cam.... was expensive. Best bet is
to install the Meziere electric water pump and depending year of car, a new timing chain cover. New valve springs a must also.
hope this helps.......... Chris
Old Feb 11, 2004 | 07:42 PM
kmook's Avatar
Advanced Tech Moderator
A true double roller is best, but some dont want a electric water pump. So the next best option is a LT4 extreme chain.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
