Lt4 springs
Old Feb 25, 2009 | 11:31 AM
  #16
95 WHITE TRANS's Avatar
It seems to be 50/50 since i have them i will run them.GM should know what their doing to sell them on the lt4 heads with the hotcam kit.
Old Feb 25, 2009 | 01:09 PM
  #17
96m6lt1's Avatar
GM offered this kit as a performance upgrade when people wanted a KIT so they did not have to search for parts! The springs are baseline springs and are rated at 100lbs on the seat which is a little better than the 85lb. stock Lt1 springs. of course the Lt4 spring will work better but will not give maximum valvetrain control. The Lt4 valves are 10grams lighter than the Lt1 valves does not sound like alot but at a higher rpm it certainly is.
It is recommended to have atleast 125lbs on the seat you cannot get that with Lt4 springs,besides adding more seat pressure will give a nice HP gain.
Lastly,i know money is tight and the idea of a 40.00 spring opposed to a 60-120.00 set of springs fit the budget but a few more bucks will not kill you. I am not bashing the Lt4 spring by any means Shon Herron set the record with them! Just stating that there are better,safer spring is widely available.
Old Feb 25, 2009 | 01:38 PM
  #18
So this springs are ok with lt4 heads?
Old Feb 25, 2009 | 05:40 PM
  #19
96m6lt1's Avatar
they are ok with Lt4 valves, but more spring is really better!
Old Feb 25, 2009 | 05:51 PM
  #20
96capricemgr's Avatar
Maybe they are on the ragged edge and some guys get away with them depending on rocker selection, exact install height or some other detail not being discussed. Honestly though valve float is extremely common and relatively rarely noticed or properly diagnosed until it is very severe.
Old Feb 26, 2009 | 04:52 PM
  #21
clwz28's Avatar
I have a set of new( drop in)erson valve springs good to 570 lift,125lb seat pressure at stock height and all you need is new locks,use stock spring locater and retainers,one of the best drop in springs $65 to your door.These springs are all you need unless your running a comp xfi or big lunati voodoo around 600 lift
Old Feb 26, 2009 | 10:11 PM
  #22
Bersaglieri's Avatar
Stop peddling your crap in all these valvetrain threads Just PM them if you want to sell them stuff.
-Dustin-
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
