LT4 spring help (install height)
Old Apr 6, 2007 | 04:32 PM
maybe2fast's Avatar
I just talked to my head guy and he said with the LT4 springs on the LT1 head he gets an installed height of 1.78 without the shims! and the shims are forty thousandths. He is worried that with the shims the installed spring pressure will be to high for the hotcam. With the shims the installed height will be between 1.745 and 1.73. Will this be okay? the pressure may be around 110-125. thanks
Old Apr 6, 2007 | 05:59 PM
stereomandan's Avatar
They are designed for the Hotcam with 1.6 RR's on stock heads. You are using the seats and retainers that go with the LT4 springs right? If so, you are all set.
The hotcam is .525" lift with 1.6 RR's.
Dan
Old Apr 6, 2007 | 07:48 PM
96capricemgr's Avatar
And the LT4 springs are too weak for the HOT cam, they work marginally well with the LT4's lighter valves though but that doesn't help you does it?
I would recommend gettung better springs before going any further. Those LT4 springs are prefect for a stock cam/1.6 rocker setup.
Old Apr 7, 2007 | 12:03 PM
I 100% disagree. There are many, many guys running the LT4 springs with the Hotcam and 1.6 RR's with no valve float or any other issues. What are you basing your comments on?
Dan
Old Apr 7, 2007 | 12:59 PM
Dan
How many "high rpm miss" threads do you see around here? How many people never even notice they are having a problem?
Valvefloat is much more common that people realize, I am basing my comments on reality rather than what "should" work.
Old Apr 7, 2007 | 08:39 PM
I've seen way too many hotcam kit dyno charts over the years that say otherwise.
Dan
Old Apr 7, 2007 | 09:31 PM
Dan
A week after they are installed, let's try a year down the road
Old Apr 7, 2007 | 09:34 PM
mdacton's Avatar
I tried em a long time ago w/hot cam stock rockers 1.5's 40# seat after 50 passes no street time
Old Apr 7, 2007 | 09:39 PM
Z-RATED94's Avatar
Dan
I agree with both of you but, why take a chance on a so-so spring? As 96 said, the LT4 had lighter valves. And who knows how long those springs will be efficient once they go through many heat cycles? I'd like to see some dyno charts of the same car with new springs (Hotcam) and then one with maybe 10k on them. Like I said, why take a chance, and or, have to do the springs again down the road?
Old Apr 8, 2007 | 04:35 PM
maybe2fast's Avatar
what springs do you guys recommend with the hotcam then? and at what install height? thanks for the help. will the hotcam be okay with the higher spring rate?
Old Apr 9, 2007 | 01:18 PM
maybe2fast's Avatar
bump.
Old Apr 9, 2007 | 05:53 PM
mdacton's Avatar
alot of guys run the behive stuff....
If you have to those springs will get you by....just know ahead of time they won't last forever
Old Apr 9, 2007 | 08:07 PM
MachinistOne's Avatar
I agree, the LT4 springs are junk...based on many engine dyno runs.
Your machinist needs to familiarize himself with roller cam spring pressures, if anything, those pressures are too low for a performance application. I do at minimum 125# seat and 295# open. Make sure he checks for distance to coil bind after max lift too.
You should get this information at minimum when a set of heads are built:
Valve sizing
Guide clearance
Spring installed height
Seated pressure
Open pressure
Distance to coil bind
Retainer to seal clearance
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 12, 2014 10:51 PM
