The LT4 "race" Intake Gasket (12367777)
Old Jul 20, 2004 | 11:49 PM
7zark7's Avatar
Has anyone measured the exact size of the intake port openings in the gasket? It would also help to get outside measurement as well to see how much I could trim it, if need be. It's a special order part that's not returnable, or so my dealer says, so it would be a shame to get one and not be able to use it.
Wondering if it will fit the big intake ports on my cylinder heads.
TIA
Old Jul 21, 2004 | 10:32 AM
arnie's Avatar
Re: The LT4 "race" Intake Gasket (12367777)
1.245" X 2.285". Center web is 7/32"......top web is 15/64"...bottom almost 1/4". Just as important is the position of the opening, heightwise, in relation to the mounting holes.
Old Jul 21, 2004 | 11:27 AM
7zark7's Avatar
Thanks a lot arnie!
Based on your measurements the height looks okay, but the width is a little too small by around 0.15". Is there room in the width to trim the gasket? I would need to trim around 1/32-2/32 off the center web and the other 0.118" from the other side. Is there enough room on the gasket to do that?
Old Jul 21, 2004 | 11:54 AM
arnie's Avatar
Based on placement of raised sealing bead, not designed for that. See it compromising seal. Maybe not on center web, but outside.......
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
ModdedNerd
Jan 29, 2015 07:23 PM
FormulaV8
Sep 1, 2002 03:44 PM
