HELP!! Elec H2o pump blowing fuses
Old Jul 21, 2004 | 09:37 AM
BLDun's Avatar
I have a CSI electric water pump that has worked great until yesterday. car overheated so I checked the inline fuse and it was blown. Replaced it and by the time I got home (1-2 miles) the guage was beginning to climb and when I checked the pump it was not running. blown fuse. I put a new relay on and a new fuse and when I start it up it blows the fuse again. Any suggestions?!?!?!?!?!?!
Old Jul 21, 2004 | 09:47 AM
944v8inDFW's Avatar
Re: HELP!! Elec H2o pump blowing fuses
Sounds like it may be time to pull the pump and see if the blades spin freely by hand. Sound like you have a bad bearing and it is putting so much load it blows the fuses. That is why i like the mechanical pump. It may leak from time to time but at least it dont stop!
Old Jul 21, 2004 | 12:31 PM
BLDun's Avatar
Found problem!!! I had just replaced the console in my '94 with one from a '98 and I had two switches and a light I had to mount on it someplace. One switch for the manual fan control, one for the left and right bank for the fuel/air ratio guage and the inidcator light for the water pump. since the two wires were the same I got them crossed when I wired them back up and it kept shorting out the fuse. rewired and all is fine.
timmy39120
May 2, 2015 05:12 PM
Klypto
Mar 9, 2015 04:25 PM
MYT30TH
Jul 28, 2002 08:47 AM
Z28BICOL
Aug 24, 2001 11:06 PM
