lt4 knock module
Old Jun 7, 2009 | 09:46 PM
94 355 lt1's Avatar
lt4 knock module
I have a lt1 that I'm rebuilding that I put pacesetter Lt's, 1.6 rr and lt4 hotcam does anyone know if I will need a lt4 knock module?
Old Jun 7, 2009 | 10:11 PM
No one actually needs one unless they have false knock. That is usually ascertained through the use of a scanner or datalog.
Old Jun 29, 2009 | 11:22 PM
94 355 lt1's Avatar
Is there a way to tell if you need one if you dont have a scanner or datalog
Old Jun 30, 2009 | 05:25 AM
The LT4 knock module was used in the 96 Corvette LT4 engines to filter out the noise from the LT4's Crane Gold 1.6 RR's, to prevent false knock retard. Since you installed 1.6 RR's, its a good possibility you may experience false knock retard. No one can say with certainty that you will or will not.
Since you can get free software for OBD-I scanning, and only require a cable, its a good idea to run a data log, rather than guess.
Old Jun 30, 2009 | 09:24 AM
94 355 lt1's Avatar
will it hurt anything if i just bought it to be on the safe side
Old Jun 30, 2009 | 09:50 AM
Stl94LT1's Avatar
No, won't hurt a thing.
Old Jun 30, 2009 | 10:09 AM
Mikes 1994 z28's Avatar
IMO the LT1 KM is overly sensative. I would register knock retard on my scanmaster even when cruising and the engine was running fine. It was pretty much stock at the time minus a catback system. I think anyone would benefit with a LT4 KM especially with headers.
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
