Lt4 knock module
Old Sep 24, 2008 | 08:31 PM
stvski80085's Avatar
Lt4 knock module
Is this something worth doing or not?
Old Sep 24, 2008 | 09:43 PM
knta4dnu's Avatar
Yes. If you have roller rockers or noise from those headers your stock module can interprit it as knock and pull timing.
Old Sep 24, 2008 | 10:08 PM
Only if you are getting false knock from somewhere.
Old Sep 25, 2008 | 07:20 AM
knta4dnu's Avatar
Shoe, is there a way to tell if your getting false knock, and am I remembering correctly that the PCM has to programmed for the LT4 module?
Old Sep 25, 2008 | 09:59 AM
JoeliusZ28's Avatar
nope, plug and play.
Old Sep 25, 2008 | 11:23 AM
A scanner and close observation should tell you. No programming.
Old Sep 26, 2008 | 11:23 AM
6SpeedIROC's Avatar
I'd stick with the stock and get a tune. If you think you have false knock download TTS datamaster and do some datalogging 9you get 20 free runs), then throw in some 110 octane and see if there is any difference.
I get less knock readings using the stock module.
I'll sell you an LT4 module that was used for 30minutes..shoot me an offer.
Old Sep 26, 2008 | 06:52 PM
1badasZ's Avatar
im supposed to have one and a tune but i get a constant 8 deg. when im cruising
Old Sep 26, 2008 | 07:20 PM
I am waiting for my cable to come in and I will start looking into the stuff. I downloaded the software and you can do more than 20 runs if you know computers a little bit like me. Just need to make sure you clear everything off and out of the registry and you should be good to go. i am sure I will have lots of questions.
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
