LT4 Knock module
Old Feb 25, 2004 | 09:26 AM
zoso1959's Avatar
Question LT4 Knock module
I was wondering if there is a way to tell when your knock module is pullimg timing?
i did have a pcm tune by ion, but i don't think i had desensitises
it when he did my tune
i would just like to know what to look for if it begins to happen.
zoso
Old Feb 25, 2004 | 09:50 AM
A scanner or scan software will allow you to monitor the knock retard that the PCM is applying, based on feedback from the knock sensor.
Old Feb 25, 2004 | 09:53 AM
zoso1959's Avatar
thanks fred
is there a way that when i'm driving her, that i would be able to
tell if its pulling timing?
zoso
Old Feb 25, 2004 | 10:04 AM
Yes... hook up a scanner. One of the things you can scan in the PCM is "knock retard"..... A ScanMaster would do this very well. Knock Retard is the default display.
While driving at WOT, sudden knock retard will be a very noticable loss of power - some people will perceive it as a "miss" or "surge". Shows up very clearly on a dyno pull as weel. A nice little "valley" in the torque and power curves.
Old Feb 25, 2004 | 10:14 AM
zoso1959's Avatar
thanks again
i'm going in a few weekd to have her dyno, that should tell
then............
tony
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
