LT4 KM Ques.
Old May 30, 2003 | 01:44 PM
Elvis '97 Trans Am's Avatar
LT4 KM Ques.
My friend and i put a LT4 KM in his car which is a '96 Z28 Convert. (OBDII).
First we disconnect the neg. batt. terminal.
Second, we unbolt the PCM from the car.
Third, we unbolt the two screws at the top where the knock module goes, take out the old one, pop the new one in.
Fourth, we waited 20 mins. before we connected the battery back to reset the computer.
He goes to start his car, and it starts then it starts idling rough and then dies, he starts it again it does the same thing but doesn't die this time, so we let it run for a minute while we wash our hands to take it out on the road. When we get back outside she's running fine, we take it on a test drive and it runs just it should, nice and smooth.
My question is, the rough idling normal or what? Because i want to add the LT4 knock module to my car but don't want to mess anything up. Any help is appreciated.
-E
Old May 30, 2003 | 02:04 PM
EvlViln's Avatar
Have him put the old LT1 KM back in and see if the problem goes away. if it does then maybe the KM is bad. If it doesnt then you have another issue.
Old May 30, 2003 | 02:17 PM
no the problem went away right before we went off driving his car. it runs fine now, i just didnt know what might have caused it
Old May 30, 2003 | 02:24 PM
EvlViln's Avatar
I am gladd to hear the the car appears to be better!
Not to be too cynical.
But just because a problem goes away, doesn’t mean that the car wont brake down later because of it. You might still want to look over the car thoroughly. IMOP
Good Luck
Old May 30, 2003 | 03:56 PM
yea i know, do u think i should put one in my car or not? do they make that much of a difference?
( he wanted to put it in his to see if it would mess up, then i could see about mine) i told him not to do that but o well.
Old May 30, 2003 | 04:01 PM
EvlViln's Avatar
I have one. But i cant say that it made much difference. Unless you have a noisey valve train (i.e. Roller rockers & descent lift) it probably wont do you much good!
But then again thats just my opinion. Good Luck.
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
jackpawt883
Aug 26, 2015 11:22 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
